06 ML350 temperature setting for heater/A/C and tailgate issues
I have been having an issue with the temperature knob getting stuck on a temperature. This only happens on the driver side temp knob. Does anyone know how to fix this?
How about fixing the tailgate not latching when using the auto close button? Also, I have been having issues with the auto close for the tailgate not working at all. Anyone have a fix? |
Hi did you solve the temp knob problem? I am having the same problem on ML 320
Problem not solved
No I have not. Please let me know if you find a solution.
to resolve the temp problem there is a software update for the acc. this has to be done at the dealer. as for the tailgate it sounds like u need an adjustment. usually you adjust the striker on the body. removed the tailgate sill plate. there are 2 t30 screws on the right side . then adjust the striker forward by loosening two t40 screws. this should make the tailgate pop open with more force and help it close properly.
Fix
Originally Posted by mercedes2006
(Post 148798)
How about fixing the tailgate not latching when using the auto close button? Also, I have been having issues with the auto close for the tailgate not working at all. Anyone have a fix? We can repair yours or supply a changeover. |
| All times are GMT -5. The time now is 07:06 AM. |
