problem with coil 4
GL500, 2013 GL Class (X166) engine 278. 130000 km.
The computer shows a problem with coil 4. I changed the coil, spark plug, injector. Programmed the control unit. The computer shows increased voltage on the coil, ignition error, short circuit in the coil. Checked all the wires - no short circuit in the wiring, everything is fine. Replaced the coil with a new one, swapped coil number 1 with coil number 4. After 100 km of driving, the check lights up. Again shows error cylinder 4. Please help Thank you in advance ALAN |
| All times are GMT -5. The time now is 10:23 PM. |
