GL-350 crank over no start
Hello I am the proud new owner of a 2011 GL-350 with a 100,000 miles
First assessment it seems to be in excellent condition ,Drives nice and starts well in cold climate . I now have a" Cranks over but no start " situation Here is what I know the last two times I toped off with fuel the reading did not register above 3/4 tank ? There was several times I went to start and it tuned over with no start after a recycle it started it ran fine but I might of noticed hesitation once or twice but not enough to get nervous I was told the fuel filter was changed when I bought it ( I am going to put an OEM one in myself for piece of mind ) I replaced the Crank shaft position sensor But that is not it checked fuel pump fuses and I am now going to check fuel pump relay my questions : 1_ if the in tank boost pump is faulty would that make sense with my symptoms ? 2_ is there a way to trouble shoot and then bench test ? 3_if they are known to be faulty is changing it good insurance ( I noticed a new part# does that mean upgraded unit ) ? 4_ would the high pressure pump fail suddenly our does it fail over time 5_ best diagnostic computer for the GL-350 ? thanks Herb https://mbworld.org/forums/images/st...ser_online.gif https://mbworld.org/forums/images/cu...ons/report.gif https://mbworld.org/forums/images/misc/progress.gif |
