Mercedes G and GL Class Mercedes G500 and GL450 SUV.
GL450 Sometimes won't start
Old 01-18-2013, 08:37 AM
POLONASH's Avatar
Default GL450 Sometimes won't start
I have a 2007 GL450 with 58000 miles that won't start some of of the time. Starts fine in the morning. After using the car it will start after sitting for a short time (20 min or less) or a long time 2+ hours but not in between? It will turn over just fine. The battery is strong and the starter works fine. It seems like its not getting gas. It'll try to come to life and rumble on for a couple of seconds then dies. I can try this 20 times to no avail. Any thoughts on what may be causing this?
Old 01-20-2013, 08:26 PM
mb1088407's Avatar
The dealer needs to run codes on it could be a feiw things.. couldnt tell ya without hookin a computer up
Old 01-21-2013, 01:36 PM
POLONASH's Avatar
Thank you. I just wanted to add that I don't have a check engine light warning.
Old 01-29-2013, 04:35 PM
POLONASH's Avatar
It's at the shop now and it's not the crank sensor. They're looking further into it. The mechanic says its losing fuel pressure when it's hot. He's ruled out any injector issues. Probably unrelated but one of the codes it gives is for EVAP emissions leak detected but he doesn't think that has anything to do with it. Maybe just a gas cap not being tightened enough at some point.
walpoleauto
01-21-2011 08:17 PM
widmer
10-19-2007 03:14 PM
LegalNeeds
06-24-2007 12:14 PM
bookerzisme
01-12-2006 08:43 PM
SL600_Cruzin
06-29-2005 11:30 AM
Quick Reply: GL450 Sometimes won't start
