2007 Benz GL450 Blistein Air Shock Absorber
I need to urgently purchase replacement part - 2007 Benz GL450 - Blistein Shock Absorber (Air filled). Part number from old part 15.1400-0381.3
PS: Not able to find this part on several auto pars website. I'll appreciate useful info on site that keeps this part and indicative price if possible. Thanks. adenationwide@hotmail.com |
the part u need should need is 164 320 6113. call the finish line 1-800-842-7851 any one of our mercedes specialists can help.
The Mercedes Benz Gl450 shock absorber is a comprising part of a suspension system and is fixed in the middle of an upper control arm and your current car frame. Inside the solidified outer shell is a pressure tube loaded with hydraulic fluid in which a piston rod moves up -down to. The rod is securely mounted on a piston, which makes this damper operate identical to an excellent oil pump. The part works in two cycles, up or extension and down or compression.
