where are my spark plugs?
There is a plastic cover runing down the middle of the rocker cover. You need to remove the intake pipe that runs across this cover. when u have the cover removed you will see 6 coils held in by some small bolts. reomve these and under these u should see your spark plugs. Good Luck
yes you can to avoid shorting, but the main thing was that it is getting high resistance already.
the point where the wiring meets the connector is the one to pay more attention.
