wheel fitment
2 Attachment(s)
hello everyone. going to throw this out there and see if anyone has tried this specific swap. founda set of 17 inch wheels ( all i can see on them is AMG) with the snow tires i need ! will they fit on my 95 e320?? i think they're off of a clk??
have the seller send you a picture of the part # stampings on the back surface of the
spokes. that should provide verification on the lip design, offset, width, etc. basing a guess off of a photo isn't a good idea |
hey thanks for the reply. they are close to me; i can look at them-offset was my only real worry. they are mounted on 215 50 tires, so not too much worried about width either. so what would the offset be represented as on the inside of the rim?
just take a photo, or copy all of the stampings. if you get the part number, we can just
translate that, or look for "ETxx" somewhere back there and the XX should be the offset |
1 Attachment(s)
so, i went ahead and got them. just went off of my judgement....only one thing i didn't think of when i dropped it off at the shop. wheel studs. oops. had to get them quick! here it is (also showing the only fubar on the car-corner of bumper)
there are 2 different ball seat sizes used by MB. your 210 uses 12 radius.
others may use 14. so you should dbl check the new wheels just to be sure proper fitment in order to retain proper ball/seat surface contact |
yeah, thanks-got that all sorted. now to fix blower motor. 6 degrees here gnar!!
