-   -   Testing Engine Compression on '94 E320 HFM engine (https://mercedesforum.com/forum/mercedes-e-class-9/testing-engine-compression-94-e320-hfm-engine-4811/)
allan l May 14, 2005 01:53 AM
Hi Guys,
Any advice on the best method of checking engine cylinder compression on Ser 104 engine (with HFM controls) ?
I was proposing to :
1. Remove Fuel Relay
2. Disconnect low voltage inputs to the 3 coil packs. Then remove one plug at a time.
3. Use a screw-in Engine Compression Tester to check pressure.
Your comments would be welcome.
allan l
'94 E320 Coupe
sleepwalker May 14, 2005 03:22 AM
RE: Testing Engine Compression on '94 E320 HFM engine
better remove all spark plugs to reduce load from the battery.
removing the connector from crankshaft position sensor on EZL will also disable the ignition.
yes, screw-in type is better.
crank 8 times is always better result.
do wet compression test too. you might need the value for making decission.
allan l May 14, 2005 07:02 AM
Sleepwalker,
Many thanks for your advice on above exercise.
How do you do a "wet test" on cylinders ?
allan l
'94 E320 Coupe
sleepwalker May 14, 2005 10:04 AM
can spray a little penetrating oil on the cylinder wall.
allan l May 14, 2005 01:00 PM
Sleepwalker,
Many thanks again for your latest advice.
allan l
