Start, Then Stall Problem
Old Jun 3, 2010 | 05:35 PM
denver_e320's Avatar
Default Start, Then Stall Problem
When I turn the key in my new (5 days) 98 E320, it readily ignites and then stops as if I turned the key off. This first only happened if the engine was warm but now happens any time. If I gently depress the accelerator for about 2 seconds during and after I turn the key, the engine stays on.
The car appears to be meticulously maintained and I haven't done a tune-up yet. Any constructive input would be greatly appreciated.
Thanks in advance
Mike
Old Jun 6, 2010 | 08:36 AM
Mcmerc01's Avatar
Does it splutter before it turns off? When you turn on the car, try to keep the revs at about 1500-2000rpm for about 2 seconds, then see if it turns off. If it does, then try again for longer or at higher revs.
Old Jun 7, 2010 | 11:34 AM
fdte320's Avatar
Looks like a crankshaft position sensor issue. First check for any code. Check Benzworld.org. This have been covered in several threads in that forum. There is also a DIY, if your are into it.
Vorbosh
Apr 25, 2011 02:02 PM
alextasch
Dec 27, 2010 05:27 PM
bluesky 2008
Apr 28, 2008 02:00 PM
TKG265
Jan 5, 2007 09:06 AM
nguyenduc09
Jul 22, 2006 09:14 PM
