Rough Idle in Warm Weather Only
My 92 300-E (3.2 IL-6) idles rough in the hot summer months (runs fine at +RPM) but in the cooler
fall/winter months, the rough idle goes away or is less severe. Had the engine scoped out by local MB-Dealership and no problems found. Was wondering if there is an O2 sensor or some other "air mass" sensor that could be causing this problem. Or, is it possible that the additives fuel stations put in the fuel in winter (emissions stuff?) could be helping the idle? Plug #5 was a little oily but only 110K miles on the engine so it should be OK. No other pressure problems, new plugs, wires, motor mounts, Cap & rotor are good according to MB tech. Hummmm? Thanks |
RE: Rough Idle in Warm Weather Only
WHat type of spark plugs?
