Reset procedure for climate control
Hi folks:::i just got the e320 with w210 climate control reset procedure which is done on the climate control itself,,i used it to reset my eco light after low freon caused it to lock out the compressor,,thank goodness it worked,,,It is not done by clearing codes on the computer but on the climate control module itself,,,:D
What is the procedure?
I've had this problem at E350 , and then it corrects itself. It seems to be toward the end of the summer when I'm operating the AC and my other member wants a hot house on her side.
I need help diagnosing a/c in my 07 e350. A/c light flashing red as well as max coo
My a/ c button flashed red 3-5 times and turned off. Max cool light flashed as well. Took to local Indy shop they clearers codes, checked Freon and pressure, compressor all good. One code will not clear. Can I try to reset?
