Replacing Belt Tensioner Pulley Bearing
Old Jun 28, 2009 | 04:10 AM
mercanlandy's Avatar
Default Replacing Belt Tensioner Pulley Bearing
I need to replace the bearing on the pulley belt tensioner on my E300D. I have got the bearing but just needed to know any tips on how to do this job before I start.
I am going to drain the coolant, remove the radiator to give full access to the front of the engine. Then, see if I can undo the retaining bolt for the bearing. Once this is done, Can I just relax the tension on the belt and pull off on to set itself ?
All advice gladly accepted.
SC
Old Jun 28, 2009 | 10:34 AM
chassis221's Avatar
what year car. this job is simple no need to remove anything but the belt. if its a 96 or newer it a piece of cake. take you ten minutes if you have the proper needed tools.
IlmoL
Mercedes A Class
May 22, 2010 03:17 PM
aldin
Aug 19, 2009 12:58 PM
wparker
Sep 28, 2007 10:19 AM
brit1967
Aug 21, 2007 07:23 AM
CmyBenz
Jul 31, 2005 03:23 AM
