Remotes won't work
I have an 03 E500, all of a suddent both remotes (with good bats) are not working. do you have any suggestions on how to approach this issue? thanx for the help
RE: Remotes won't work
test the fuse.fuse list by the battery.ohlord
which fuse? did you mean the 4 or so fused right next to the battery in the trunk?
Fuse list looks like this http://www.benzworld.org/forums/w210...ist-fuses.html
Check with a multimeter fuses listed under central locking system ,ohlord
check fuses on rear trunk fuse num 8 is for remote central lockin.......................
Thanx for the reply, i'll check fuse 8 in the morning and let you know :)
| All times are GMT -5. The time now is 09:18 AM. |
