a overheating miracle
:Dwell i have a overheating problem ....well...i decided to turn the heat on to see if it would cause temp to go down(below 80)and it did...then i turned on the ac to see if it would stay down and it did....the i turned it off to see if it would go over 80 and it did....so i decided to turn the heat on when its cold outside or turn the ac on when its hot outside until i can get it fix....this was truly a miracle;)
RE: a overheating miracle
Thank goodness for the thinkers in the world.
:eek:it will work temp.only......
:Dyou did that and no mechanix have a lunch.........[8D] |
| All times are GMT -5. The time now is 07:45 AM. |
