overheating 190e
Old Nov 24, 2007 | 07:34 AM
  #11
rodnie's Avatar
Default RE: overheating 190e
My 190e86 is overheating what can i do , i put a new water pump in it thermostat and had it flushed. changed the top gasket twice and the cylinder.Still the heating will not stop.
Pls,I need help asap,as the car is my only means of movement.
Old Nov 24, 2007 | 07:41 AM
  #12
rodnie's Avatar
My 190e86 is overheating what can i do , i put a new water pump in it and flushed the radiator.Ive changed the top gasket twice ( withinn 2 days)and the cylinder.Still the heating will not stop.
Pls,I need help asap,as the car is my only means of movement. Pls Help.
Old Nov 24, 2007 | 02:11 PM
  #13
ohlord's Avatar
Banned
You changed the head gasket?Have you checked for coolant in the oil?You may have a cracked cylinder wall,run a leak down test,to determine where the water is going.Also when the a/c is on does the aux fan turn on and prevent the overheating?
Old Nov 24, 2007 | 03:07 PM
  #14
NAZ's Avatar
NAZ
if it its head gasket u wont get heat on stand stilllllllllllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllllllllllllll lll,his heat is desperin when he drives common sense its a thermostattttttttttttttttttttttttttttttttttttttttt ttttttttttttttttttttttttttttttttttttttttttttttttt
Old Nov 24, 2007 | 11:32 PM
  #15
ohlord's Avatar
Banned
Rodnie,changed his thermostat and the overheating still continues.So "common sense" would dictate he has a compression leak into the coolant system and that is his next avenue to pursue.
ohlord
Old Jul 12, 2008 | 09:10 PM
  #16
AlexanderT's Avatar
Are there any diagnostic procedures? It is possible to replace all Cooling System...
I want to check: Radiator (which is cold at 100C), Sensors, and Relay. I removed a thermostat completely.
Old Jul 14, 2008 | 11:09 AM
  #17
ohlord's Avatar
Banned
pressure test cooling system.test strips to check for combustion gas in the coolant.replace the thermostat,it is needed to slow the coolant flow enough to cool the water in the radiator.Old model,check your ignition timing.Too far retarded and it will overheat.
ohlord
Old Dec 14, 2008 | 05:55 PM
  #18
phoenixrayne's Avatar
I had an overheating problem similar to all these on my 88' 190E. I had replaced the thermostat. Checked the fan, flushed the radiator and had even done a flow test on my waterpump at running temp. Like i see in many of these posts it seems as though the car would run fine for 30 minutes to an hour then just spike and boil out. After replacing everything and checking the waterpump i still had the issue. Mind you at this point i hadnt replaced the water pump and it was my last option. Come to find out when the water pump would start climbing torward the 100 degree mark the drive shaft inside would seperate from the impeller and cause a failure and in turn causing the car to overheat unpredictably. After changing the water pump everything now runs fine in the normal range between 90-100 degrees without a hickup. Just thought id share my experience with those of you with similar issues.
190edude
Jun 20, 2016 10:56 AM
ssph
Jun 21, 2007 11:57 PM
190edude
Aug 24, 2006 12:35 AM
MASSINC
Oct 14, 2004 01:46 PM
anotherlemon
May 16, 2004 01:53 PM
