-   -   Location of Crankshaft Position Sensor and Fuel Pump Relay-01 E320 (https://mercedesforum.com/forum/mercedes-e-class-9/location-crankshaft-position-sensor-fuel-pump-relay-01-e320-19215/)
BenzoDJ Mar 29, 2007 06:16 PM
Where is the Cranshaft Position Sensor and Fuel Pump Relay Switch located on an 01 E320. I think the Sensor is located on the rear of the engine. If so, do I gain access to the Sensor from the engine compartment or from under the car? Where is the Fuel Pump Relay Switch located? Your insight will be appreciated.
snanceki Mar 30, 2007 03:37 AM
RE: Location of Crankshaft Position Sensor and Fuel Pump Relay-01 E320
CPS. At the back of the engine on the bell housing towards the top. Not sure on E class but would expect this to be from under the bonnet.
Easy replace job.
Neon Mar 30, 2007 02:34 PM
http://www.detali.ru/cat/oem_mb2.asp?TP=1&F=203061&M=112%2E912& GA=722%2E696&GM=716%2E623716%2E634&CT=M&am p;cat=19X&SID=15&SGR=075&SGN=04
As borrowed from the C-class forum. This is the picture of the M112 CPS location.
The fuel pump relay is in the fuse box on the driver's side. Look for part no. 002 542 13 19
BenzoDJ Mar 30, 2007 08:01 PM
Thanks guys for the information. Very helpful.
