-   -   left turn signal stuck (https://mercedesforum.com/forum/mercedes-e-class-9/left-turn-signal-stuck-5955/)
nlorz Aug 5, 2005 07:25 AM
does anybody here experienced their turn signal stuck? my LEFT TURN SIGNAL is stuck whether its on/off position.[:@] my right turn signal works okay.
any advise is much appreciated. thanks
car info:
2001 E200 Kompressor
VIN: WDB2100482B38817
ENGINE: 11195732230619
sleepwalker Aug 5, 2005 12:18 PM
RE: left turn signal stuck
electricals.
only by diagnostic test that you can confirm the source of problem.
nlorz Aug 6, 2005 04:27 PM
thanks bud... i guess i have no choice but to take it to dealer.:)
brianbelfast Aug 7, 2005 06:09 AM
If you have an aftermarket / non-mercedes car alarm fitted. And this alarm flashes your indicators. This can be the problem. The relay contacts in the alarm unit tend to weld together leaving one or both indicators constantly lit. As a quick test, disconnect the multiplug from the alarm and see if the light goes off. If the alarm manufacturers would use a relay capable of handling the current involved in flashing front and rear and side repeater bulbs all at once ( up to 5 amps in some cases ) we wouldn't have this problem.
Hope this helps.
Brian.
nlorz Aug 7, 2005 11:42 AM
thanks for your advise Brian. but i dont have aftermarket alarm systems installed on mine
so i dont think thats the problem.
any more ideas guys? thanks....
AV02CLK Jun 22, 2023 07:50 AM
Just had this problem in my 02 clk320. Took it to a german shop and its the combination stalk. they charged me 150 for part and 300 for labor.
manicmechanic007 Jun 25, 2023 07:33 PM
Right, it should be the multi function switch or the flasher relay
And if it is the stalk that is what? frozen? Yes, it will need to be replaced
Those above numbers sound about right
