Interior Light
My interior light relay bulb is burnt out, and would like to replace it. I've checked the manual and it doesn't really show how to replace it. The light bulb I would like to replace is located in the center top where the switches for book reading, door relay, etc...
Also, my transmission light is burnt out as well. It's hard to switch gears at night when there's no light. I have 300E 1990 model...please help! Thanks! |
RE: Interior Light
push the two locks on right side and pry it down.
[IMG]local://upfiles/1/8B5F094466094CE59764BAC5CB3BA687.jpg[/IMG] [IMG]local://upfiles/1/14540102259C48468C1150E8CB2F34EF.jpg[/IMG] |
RE: Interior Light
Wow..thank you so much with the whole pictures thing. It makes it a whole lot easier. Again thank you!;)
RE: Interior Light
you're welcome
RE: Interior Light
Okay, same car...how to replace front speakers? Or even back speakers? Thanks in advance!:)
RE: Interior Light
in the front, you need to remove the door trim first (door cover, panel or whatever it is called).
[IMG]local://upfiles/1/F9AE6C05D0FA430F8A28019A5DDE842E.jpg[/IMG] |
RE: Interior Light
Thanks but one question, I believed the speakers are in the dash board. What door trim?
Thank you in advance. |
RE: Interior Light
frankly, if you cannot identify the parts using common sense, it will be difficult to open it.
...if there's anything else attached to your door from the inside, that was it. [IMG]local://upfiles/1/8ECBC07A30B6484BAAD9587AD9EB992A.jpg[/IMG] |
RE: Interior Light
Okay, this was a much clearer picture than the last one. Thank you.
