I damaged a vacuum line, need help!!!
I was pulling off the ICV and needed to get the small stiff hose that goes into the air cleaner/valve cover hose out of my way. I pulled it and the rubber hose that goes into the small canister came out. Well as i looked, to return it back to normal, that hole it was into on the canister is half the hose size. the hose has a sort of "bell" on it to keep it locked in place. I punctured it trying to push it back in. Does anyone know what the name of this assembly is on the throttle body?
Ha! Seems this is the fuel pressure regulator. Hate it when it's cold outside, don't have the ability to stay outside and tinker. Certainly is a tight spot! Being cold as heck outside, it's not going to help my no-start problem now. |
