help removing glove comp ASAP E320 -01
How to remove glove compartment on a E320 -01. I have remover 2 screws a bottom, 2 screws upper front, 2 screws upper inside, 1 screw behind compartment light. The whole box is loose but still its stuck somewhere.
Is it just to pull? Im afraid to ruin something. Is there some special thing to do to get it loose. Feels like its stuck in the upper part the bottom part is really loose when I pull it. |
RE: help removing glove comp ASAP E320 -01
I got it out. Damn.... thought I was going to tear that car apart compleatly. You have to bend down the upper edge of the compartment to get it loose from the dashboard....
wasn't it just illumination lamp that keep you from pulling it out? pushing it down a bit is okay.
| All times are GMT -5. The time now is 04:58 AM. |
