head gasket question
I have a 1992 190E which needs a head gasket repair.
I am looking online for the head gasket and I'm finding prices all over the place, from about $30.00 on up to around $75.00. Also, the online vendors I've checked list only one gasket, even though the six cylinder version was offered with both the 2.3 and the 2.6 versions. I have the 2.6 in mine. Did both engines use the same gasket? |
Originally Posted by llamov
(Post 161095)
I am looking online for the head gasket and I'm finding prices all over the place, from about $30.00 on up to around $75.00. Also, the online vendors I've checked list only one gasket, even though the six cylinder version was offered with both the 2.3 and the 2.6 versions. I have the 2.6 in mine. Did both engines use the same gasket? Pelican Parts.com - Parts, Accessories and Technical Information for all Mercedes-Benz Automobiles. |
Answer
(Post 161095)
I am looking online for the head gasket and I'm finding prices all over the place, from about $30.00 on up to around $75.00. Also, the online vendors I've checked list only one gasket, even though the six cylinder version was offered with both the 2.3 and the 2.6 versions. I have the 2.6 in mine. Did both engines use the same gasket? Be sure to have the head inspected and tested, as a cracked cylinder head is common for both engines when overheated. If you need DIY data or tech support, contact me. whunter@pelicanparts.com . |
