Hard starting probem??
I have a 91 300E. I have a problem, where whenever its cold outside, the car wont start. But when it is in a warm place overnight like a garage it starts instantly the next day. I have changed the spark plugs, cables, distributor ca[ and the cold start valve. If anyone has had this problem and could help me out and replys would be very welcome. I was told that it might be a problem with some kind of sensor.
thanks, darko |
RE: Hard starting probem??
insure that the spark plug heat range 145 are installed.
Bosch H 9 DC Bosch H 9 DCO |
hi thanks for the reply. But i really dont understand what youre talking about? If you could explain to me what a spark plug heat range 145 is??
thanks, darko |
tell me your spark plug number and i will explain.
well today i looked up thee spark plug number.and its RO285. Thyer bosch spark plugs. Any of your help weill be greeatly apreaciated.
thanks |
RO285 |
RO285 |
Hi wehn i looked there was no other number on the spark plug. All it says is Bosch and the number I posted. IF you think the problem is with the plugs, could you tell me which ones you think will solve ther problem.
thanks, |
the numbers mentioned above are the ones intended for your car.
