-   -   Good Vibrations .... I think not! (https://mercedesforum.com/forum/mercedes-e-class-9/good-vibrations-i-think-not-14916/)
Nello Oct 5, 2006 09:16 PM
I have a 1996 E320 UK spec.
the whole car vibrates at 25-30 mph, 50-60mph and at a ... well lets say and illegal speed.
i had the prop centre bearing replaced that did help matters, all wheels and tyres are new and have been balanced 3 times. (the old set were just as bad if not worse, so its not them)
suggestions are propshaft flexi couplings front and rear or bottom wishbone balljoints or wishbone oilite bearings.
any comments please. i dont want to spend hundreds on this (but already have)
jmang09 Oct 6, 2006 09:35 AM
RE: Good Vibrations .... I think not!
checked tie rods and center link? does it vibrate from the floor and the steering wheel?
nkpnkp Oct 6, 2006 10:27 AM
Usually front and rear flex disc
Nello Oct 6, 2006 07:29 PM
can i have a bit more detail on what the centre link is,
you have described the problem exactly
floor and wheel wobble.
snanceki Oct 7, 2006 04:47 AM
In my view if you are getting this at 25mph it is NOT normal wear and tear associated with normally worn ball joints, bushings, out of balance wheels etc.
When you say "vibration" do you mean a physical oscillation (regular frequency) or is it just a noise you are hearing or even possibly something intermittently banging around under the floor (eg exhaust).
Assuming the former the most likely cause is the propshaft "dougnut(s) disintegrating".
However bad wheels (and tyres) are also a real possibility but you state you have fitted "new" ones. New or just a different used set?
Stuart
Nello Oct 7, 2006 08:38 AM
Thank you for the responses.
the wheels are brand new and so are the tyres.
I am about to order the front and rear flex disks.
I'll let you know how I get on.
snanceki Oct 7, 2006 03:44 PM
You didn't respond to:
Stuart
Nello Oct 9, 2006 07:02 PM
there is oscillation at the steering wheel as if a wheel is out of balance.
there was also heavy vibration under the seat before i changed the centre prop bearing, its now further towards the front of the car.
the exhaust and underside is all sound
97dmsrS420 Oct 10, 2006 02:12 AM
If replacing the flex discs and center support bearings don't fix it, then, more than likely you will need to replace the driveshaft.
snanceki Oct 10, 2006 04:04 AM
OK,
For there to be such a significant oscillation at the strg wheel something significant must be "forcing" the system.
The only component likely to do this (after eliminating the road wheels and tyres) is the engine itself.
Have you checked that the engine and transmission mountings have not separated at the metal/rubber bond due to corrosion or oil contamination.
Stuart.
