funny noise when turning wheel
Old Nov 24, 2004 | 01:53 AM
jvision09's Avatar
Default funny noise when turning wheel
i hear a funn noise when i turn my steering wheel all the way to the last possible place..and the car shudders a little bit.....the noise is loud like a crazy vibration..i have no idea why it does this..any help is appreciated..thanks.....94 E320 Sedan
Old Nov 24, 2004 | 03:24 AM
sleepwalker's Avatar
Default RE: funny noise when turning wheel
gurgling noise?
high pitch noise?
when you turn the steering to lock on one side, the valve on the pump is fully close. the pressure build up is too high and the oil will escape through release or bypass valve... hence the noise is heard.
the gurgling sound could be from the oil reservoir.
(we are talking of power steering here).
remedy: don't turn the steering to end stop or else the hose cannot withstand (my spelling is right?) the pressure and might leak.
adjust the steering end stopper so you won't reach that point.
nothing is wrong with the car.
Old Nov 24, 2004 | 03:28 AM
jvision09's Avatar
cool...thanks sleepwalker
Old Nov 24, 2004 | 08:00 AM
Shovelhead's Avatar
Had a problem that sounded similar to yours... Check if you start loosing power steering fluid in the future. I ignored the problem and ended up needing a new steering rack ('96 E320). The seals in the piston that is under the boot let go. Also make sure you use Mercedes power steering fluid only.
Old Jan 26, 2005 | 05:36 AM
sokhoms's Avatar
Try to replace this old fluid by sucking it out from a resevoir with a serange and refill with lucas steering fluid. I think it should be fine.
Jpro
Feb 15, 2009 05:46 PM
books
Feb 10, 2009 04:24 AM
andrewowens
Apr 26, 2008 11:20 PM
rogerwilco
Feb 1, 2005 11:43 AM
gtoofany
Oct 24, 2004 04:58 AM
