Engine Oil HELP!
Old Apr 8, 2012 | 11:04 AM
bienci's Avatar
Default Engine Oil HELP!
Just went to a local mechanic to change engine oil (E320). The mechanic put in 5W20. Later I found out that 5W40 is recommended for my car but the mechanic said it should not make any difference and I should be fine. Is this correct? No damage whatsoever to the engine? Thanks.
Old Apr 8, 2012 | 12:44 PM
chassis221's Avatar
dont worry about it. just put 5-40 in at next oil change
Old Apr 10, 2012 | 10:01 AM
BikerDrew's Avatar
It's the lower of the two numbers which is probably more important since you will get valve and lifter noise if oil is not thin enough. So, you are Okay until next time.
Old Apr 11, 2012 | 06:29 AM
bienci's Avatar
Thank you all for your comments. I really appreciate it!
rx7pro
May 3, 2009 07:45 PM
mercedes4life
Feb 14, 2007 01:58 PM
adazz
May 30, 2006 12:38 AM
BenzoDJ
Mar 13, 2006 01:14 AM
