E430 Service Due Light-how do I reset it?
Hi, I have recently bought an 1999 E430 and my service due now light has come on. I was wondering is there a way to reset it. I service the car myself as I am a qualified mechanic, however I don't know how to clear it.
Thanks in advance Schnezza |
RE: E430 Service Due Light-how do I reset it?
Key on (position 2, all idiot lights come on, engine NOT running)
PUSH the trip odometer reset knob twice rapidly, the time/distance remaining for FSS is shown. PUSH button in and hold it in. Turn key OFF (DON"T release the button!) Turn key back to position 2....KEEP holding the button down! You'll need to hold it down over 10 seconds, you'll hear the beep and 10000 will be the new display. DON'T release the button until you hear the beep. The (O) button is the one Make sure the doors are closed Have fun, ohlord It also should be in the owners manual.... |
Thank you so much.
I am enjoying this site already. I have printed your reply and will head to car and rectify it. Cheers Schnezza |
I did it. It took 15 tries but I got it in the end.
Cheers Schnezza |
I should have thought to tell you it might take a few tries..........It's not the system,its in how to do it.You have to really quickly press the o button twice,like twice in a half second,thats the trick!!!
glad it worked out. Also concider joining mbworld.org w210 and benzworld.org w210 great diy section and a lot of the same members,you could build a benz with all the knowledge base on the three sites!!!! ohlord |
Hey ohlord does this work on a 2002 E320 Sport?
Nope, that one requires the steering command buttons use.Do you have the owners manual?
ohlord |
service system 116
Technical data Instruments and controls Operation Driving Instrument cluster display Practical hints Car care Index Following a completed A or B service the Mercedes- Benz Center sets the counter mileage to 10 000 miles (Canada: 15 000 km). The counter can also be set by any individual. To do so: Turn the electronic key in steering lock to position 2. To call up the trip odometer and main odometer, press button è or ÿ on the multifunction steering wheel until the display appears. See page 96. Press button j or k until the FSS indicator appears. Press button J on the instrument cluster for approximately 4 seconds. The multifunction display will show the question: “DO YOU WANT TO RESET SERVICE INTERVAL? CONFIRM BY PRESSING R” Press button J on the instrument cluster again for approximately 4 seconds, and hold until a signal sounds. The message “SERVICE INTERVAL HAS BEEN RESET” appears in the multifunction display. The new service indicator is displayed with the reset distance of 10 000 miles (Canada 15 000 km). From my handy dandy copy of an 02 manual ohlord do you need a manual? |
It works. Just make sure the doors are closed. Idk why..
What ohlord said work great for a 1999 E430 to reset the 10,000 service. put key in 2 position press "0" twice very fast. Now press and HOLD "0" turn key back to off and then back to position 2 hold until resets to 10,000.
