E230 Auto Overrun thump when I brake - Any Ideas
My pride and joy E230 Auto has only one problem. When I brake following a period of time on a straight road, the car seems to experience a thump like someone has bumped into my rear end. It seems to me as if the clutch orsomething isn't disengaging the drive on time. Is this a common problem and can someone help me diagnose the problem. Much obliged for any help. |
RE: E230 Auto Overrun thump when I brake - Any Ideas
Is this when you brake or go onto overrun i.e. just engine braking. Tryt repeatedly applying power and then off in a rythmic pattern a few times. If the later it is likely the diff mountings especially the diff nose. If the former then I suspect a suspension bushing is shot or loose. I assume you have nothing loose in the boot / under rear floor. e.g. Battery? Mileage? Vehicle history? Might help locate problem. |
Thanks that gives me something to discuss with my mechanic friend.
My car has 140,000 miles with a good service history and runs very well. I usually experience the problem when i've been on the motorway and come off an off ramp slowing to a stop with gentle braking. It can also happen in town when stopping at traffic lights. I'm confident its not anything loose in the boot or bonnet. |
I should have clarifies that it occurs when the car is almost ata complete stop.
Have a mechanic look at the drive shaft... my car has a clack noise just before to come at full stop..
maybe the differential?
ORIGINAL: leon s. ... my car has a clack noise just before to come at full stop.. I do not actually know what makes this noise. I suspect that it is something in the gearbox. I will find out since I am also interested unless of course somebody watching this thread already knows. Stuart |
Ju8st to clarify further, there is no actual noise that can be heard whilst driving. The thump is a physical lurch forward with no perceptible noise. The explanation that it could be a delay in the gearbox changing down from 2 to 1 seems plausible to me.
Thanks for the ongoing interest. |
