E200 rear wheel bearing replacement-Difficult?
Old Nov 9, 2006 | 06:14 AM
fettners's Avatar
Default E200 rear wheel bearing replacement-Difficult?
Is it difficult to replace the rear wheel bearing?
What are the steps?
any advice?
I've bought a hub puller and bearing puller.. So ready to go?
oh, its a 1998 (S reg)..
Thanks,
Steven
Old Nov 11, 2006 | 03:25 AM
vytamenc's Avatar
Default RE: E200 rear wheel bearing replacement-Difficult?
it is very simple to do with both of those tools. just use common since when doing it. also when your pressing the hub back in be sure that you have a backing plate on the back of the bearing when your installing the hub. or you will push the rear race right out of the bearing when you install the hub
Old Nov 13, 2006 | 07:22 AM
fettners's Avatar
WELL JOB DONE.I won't say it was easy. Complicated by the fact tha bearing had cracked and fallen apart in there.
But all done and on the road for £80. £13 of it was for a part I didn't need.
but done is done.
Old Nov 14, 2006 | 01:19 AM
vytamenc's Avatar
did the new bearing split down the middle when you installed it
Old Nov 14, 2006 | 04:57 AM
fettners's Avatar
I don't know what you mean, so I can only guess the answer is no. It was one big solid bearing. which we tapped into a housing in the car. We heated up the housing to expand it (the axle sticks out through this), tapped the bearing in. then put the hub back into that. Sorry to be so vague, but I don't know the names of the parts. Hope that helps.
mick.anic
Apr 17, 2013 12:30 PM
bradw24
Nov 18, 2008 08:52 PM
Andymon
Oct 27, 2007 10:58 AM
fettners
Dec 6, 2006 09:41 AM
UberDiesel
Dec 13, 2005 09:49 PM
