coolant change E320 2000
Am going to change my coolant and have not done it before. Need I only remove the lower hose and let it drain?
Brad |
RE: coolant change E320 2000
there's a drain plug on the radiator.
loosen it and keep the reservoir cap open. |
Thanks for your reply . I am assuming that this will drain both block and radiator. Then I just replenish with MB coolant at 50/50 and no need to flush..?
Brad |
it won't drain the block, but it doesn't really matter for you have to flush it once.
fill with pure water, run engine till 80 degrees, drain and refill with 30-50% coolant mix. |
Dangerous?
Fellas, I am about to do the radiator drain myself. The question that I have concerns the fill with pure water... won't that boil when brought to 80 degrees Celcius? After it hits that temp and the car is turned off.... I should wait an hour or so to drain the water... right? After that I can fill with the MB coolant at a 50/50 distilled water mix ratio.
Does the pure water cycle really do a flush job? Would a store bought flush like Prestone's Super Flush be beneficial or harmful? Thanks in advance. |
| All times are GMT -5. The time now is 10:01 AM. |
