Cold Start Fix
Old Dec 21, 2010 | 07:04 AM
missamerica's Avatar
Default Cold Start Fix
After many other posts I have found that the cold start problem may be simple.
What I am pointing out is the common sense Tech's should already know.
Here you go
You say
well
It ran last night.........???????????
Low voltage , Fuel, spark, limp mode,..chances are there ok
Simple thought here is its cold...........
turn on the car .................listen for the fuel pump, OK
turn the motor over and right then you should know its spinning normally
no start yet ..just spinning
Its the Crank sensor plain and simple
Use ONLY OEM on this part..............$170
Reason
The specs on it are very tight for high temp and cold.
Thats right Hot and Cold
The signal to the computer HAS to be within a very tight range for it to
let the motor start.
Cold Start Fix AND Hot start too!
hope this helps
M
crusier888
Oct 13, 2019 04:46 PM
tomfer114
Oct 15, 2010 08:53 PM
Longhaily
Aug 2, 2008 07:28 PM
jbellia
Jul 16, 2008 08:39 AM
bluesky 2008
Apr 28, 2008 02:00 PM
