-   -   Check Engine light 1995 e320 code 10 (https://mercedesforum.com/forum/mercedes-e-class-9/check-engine-light-1995-e320-code-10-a-24601/)
kranje Nov 5, 2007 08:01 PM
Can any one tell me what code 10 Voltage at air mass meter to high or low means. Is the sensor bad or wire harness no good. I got 10 blinks on the self diognostic plug by the battery which is 16 pin plug (obd I). The car rough idles when you release the accelerator for a few seconds and smooths out and hesitates between 2000 to 3000 RPM over 3000RPM accelerates fine. Any suggestions is appreciated. thank you.
