-   -   Auto Transmission Fluid and Filter Change (https://mercedesforum.com/forum/mercedes-e-class-9/auto-transmission-fluid-filter-change-3058/)
handyjay Dec 1, 2004 01:25 AM
I am ready to change my AT fluid and filter. Any special issues, other than extreme cleaniness, that i need to be aware of? Thanks.
sleepwalker Dec 1, 2004 01:51 AM
RE: Auto Transmission Fluid and Filter Change
drain the torque converter too and replace the ATF filter.
handyjay Dec 1, 2004 10:20 AM
I know where the drain is for the transmission, but not the torque converter. I assume I remove a cover plate and rotate the converter to a drain plug. Does it fill when I start the engine and put it in gear? Thanks
sleepwalker Dec 1, 2004 11:56 AM
yes, it fills itself easily.
remove the cover, turn the torque converter and you will see the drain plug.
Buck Dec 12, 2004 10:51 PM
I paid to have my flid and filter changed about 30K miles ago, I would like to do this one myself. Would it be ok just to change the fluid and not the filter at this time?
sleepwalker Dec 13, 2004 06:11 AM
on transmission, yes. but on engine, always change the filter too.
