99 E320 SEDAN STALLING WHEN WARM
I have a 1999 E320 that stalls out on me once it is warm. I wait 15 to 20 minutes and she starts right up, but stalls out after a couple of minutes. I have replaced the fuel pump and filter. Any ideas from anyone would be appreciated. It has a little over 101,000 miles. Also the BAS/BSA light comes on when it stalls.
RE: 99 E320 SEDAN STALLING WHEN WARM
Classic crank position sensor failing.Fix it before it goes dead and you will not get stranded.
www.autohausaz.com http://www.autohausaz.com/search/pro...ition%20Sensor have your vin or production date on hand when you order so they can send you the correct one. DIY on mercedesshop.com diy section w210 cps and on benzworld.org w210 diy section. good flashlight helps see around back there. If you diy about 60-70 bucks to repair a lot more if you go to a shop or the dealer. ohlord |
Hopefully this works. ordered the part and will find out by end of week if this is the fix. Thanks I will keep you updated.
yeah cps i just did mine 10 min
It worked. Changed the cps and no more stalling out while driving. Thanks a bunch
