98 E320 stopped inthe middle of the road...Please help !!!
Thanx a lot !!! Yeah I hope it will help !!! How hard is it to replace this sensor? do I need to go underneath the car to take it out? What tool do I need ??? I think I know aproximately where it is located.....
I have the same exact problem with my 2000 E430, sometimes won't start, sometimes stalls. Was also told by Mercedes it is the crank position sensor. Does anyone know if the stall problem can occor when driving at any speed, or does it happen only when stopped or at idle? I am really worried about the car stalling on the highway.
Yes it can stall at any speed if it fails completely while on the road.Fuel shuts down because it is not getting any signal of the proper crank position.Order the part from autohausaz.com about 50 bucks delivered and follow the diy on benzworld.org w210 section or on www.mercedesshop.com
You can do it ,if you follow the easy directions.If jennycat means you are of the fairer sex,don't let that stop you,I have talked many through far harder diy's.Dealer will rip you off.
ohlord
ohlord
E320SPLN
Jan 10, 2009 05:02 AM
MARIODRIVE
Nov 23, 2008 05:39 PM
