96 e300d window reprogramming
I recently changed the battery due to an alternator problem. My wife's driver window will not come up.
only when you use the trunk option to lock then the window will come up. Is there a reprogramming of windows or do i have another problem with the window motor? Any suggestions will be greatly appreciated. mike |
RE: 96 e300d window reprogramming
there are 2 positions in your window switch-- the slightest touch is manual- if you feel a detent in switch you are in auto up feature- to reprogram window after the battery replacement- you use soft touch (manual) and roll window down-hold for 30seconds then soft touch up and hold for 30 seconds-- if window is down currently- use soft touch up- then perform procedure--do this to all 4 windows--
