95 E 320 intermitent non start
95 e 320 intermitent non start
been to mb replaced cps, all relays by battery, ecu, starter motor, ignition pack still intermitent non start it looses spark & injection pulse some times will be fine for weeks over times every day please help costing me a fortune |
RE: 95 E 320 intermitent non start
Does it ever happen that when you turn your ignition on, that the dash lights do not come on??
If it does, then you need an ignition switch. I have seen this happen on a few 95 E Class. The other thing, which you may have had replaced, is the overvoltage protection relay, which is a silver relay with a fuse on top. Check this relay and its connections. |
replaced ignition & the over voltage protection relay weeks ago still the same
replaced ignition & overvoltage relay weeks ago still the same
