93 300E climate control does nothing???
Hi Guys,
I just purchased a 93 300E, 2.8. This car is like new! I couldnt pass it up! There is one problem, the entire climate control system is out. Nothing blow, it seems like it may only be a fuse or relay....... I checked the fuse in the engine compartment, that is good....Any direction would be greeatly appreciated..... Cars with no a/c in Florida are not a pleasure to drive! Thanks, Bob Held Norht Port, Fl |
Have you checked the strip fuse next to fuse box? It could be cracked. You have to use Philip screw driver to replace the strip fuse.
Thanks for that info, I will check that tomorrow
| All times are GMT -5. The time now is 03:48 AM. |
