-   -   4Matic light on (https://mercedesforum.com/forum/mercedes-e-class-9/4matic-light-19132/)
Vitaman Mar 26, 2007 04:36 PM
4Matic light on
[:-]4matic Dash light staying on. Added Hyd fluid(MB) to the reservoir as it was a little low. Reset light via a battery disconnect. Light returns after apprx. 50 miles. Any checks I can do for possible simple fix. Transfer casehas apprx. 50,000 miles since replacement. Thanks.
Vitaman Apr 15, 2007 12:12 PM
RE: 4Matic light on
I removed what could be called a bleeder screw (plug) located at theservice valve lever, while the eng was running. Bled off a little fluid and hopefully any air that might have gotten into the system. Nothing more than a guess.I took it out fora little test run on the snowy road, engaged the 4 Matic several times and all seems fine.
