300TE
After decelerating from 40 to 10-15mphish to make a turn the car likes to (occassionally) quit. I coast over to the curb and shut everything down and restart. It will run fine after that possibly until the next day +/-. There is no real pattern other than it only happens when turning and right more than left. Highway driving is OK. Year is 1989.
I appreciate the input. Dondas- last year about this time you did in fact help in the diagnosis of my 500 SEL//ASR Fault/ it was and still the electronic acceletator actuator. Thanks |
RE: 300TE
Clean the "butterfly" of the throttle body. If problem still persist, you may need to change the throttle body.
NPK |
RE: 300TE
also check all the vacuum hoses for crack, loose fittings and so on...
