E430 ESP ABS BAS malfuction
Old 11-13-2004, 01:30 AM
GP's Avatar
GP
GP is offline
Default E430 ESP ABS BAS malfuction
I have a 2000 E430 (59,000km) which every few weeks has been indicating a ABS, BAS, ESP malfunction. The malfunction code reads "faulty yaw rate sensor", which I have had replaced, and the wiring inspected and terminals cleaned at both the sensor and control unit ends, all to no effect. In all cases the message has come after the car has begun moving, though ever so slowly, as most have occurred as I have slowly crawled out of the garage into the back lane that leads to the street. The manoeuvre involves first full lock steering to the right and then full lock steering to the left as I negotiate the laneway, and then full lock steering to the left as I enter the street. Speed would be slow walking pace. Most times the message has come during or just after the turn to the right in exiting the garage. The last message came during or just after the left turn entering the street. The car has been cold except for this last message, when it had been run before and was warm. My mechanic now suspects the control unit. The brake light switch was also suspected at first but the error code is definitely naming the yaw rate sensor. Any other ideas please?
Old 11-13-2004, 04:21 AM
sleepwalker's Avatar
Default RE: E430 ESP ABS BAS malfuction
there is service measure on it about the repair of wiring harness on the control unit connector.
the moisture penetrates inside and disrupting the signal.
check it.
Old 11-13-2004, 04:44 AM
GP's Avatar
GP
GP is offline
Thanks - can you give me an address or location for the service information?
GP
Old 11-13-2004, 07:36 AM
on monday.
check from this post... remind me in case i forget.
am still on 2 days rest.
Old 11-15-2004, 08:17 PM
GP's Avatar
GP
GP is offline
A reminder - any luck with that service measure?
Old 11-15-2004, 08:35 PM
oh, sorry GP... i forgot yesterday.
i will be on field service for another two days. i will post it after i'm back, okay?
cheers.
Old 11-15-2004, 09:24 PM
GP, i need the fault code number.
still got many info about it and i want to narrow it down.
give me your VIN too.
got to rush out now.
[IMG]local://upfiles/1/1410C4A18C0646528F7638F709A7FC23.jpg[/IMG]
[IMG]local://upfiles/1/E76B7AC7B5694844BBA24D0418F838A5.jpg[/IMG]
Old 11-22-2004, 02:21 AM
GP's Avatar
GP
GP is offline
Thanks for those Bulletins. I finally got the code, which is C1120 "ESP yaw rate sensor."
There is also a short steep ramp from the garage to the laneway which I drive down and the fault occurs just after I have turned off the ramp. Someone else has said the ramp is involved. If the ignition is turned off then restarted the fault disappears, but is stored in memory.
Cheers,
GP
cobracop
03-11-2013 09:23 PM
BenzoDJ
02-26-2006 12:02 AM
BenzoDJ
02-24-2006 12:14 AM
manaiauds
02-19-2006 12:55 PM
uberwgn
09-20-2005 01:55 AM
Quick Reply: E430 ESP ABS BAS malfuction
