-   -   2002 E320 car will not shift gears (https://mercedesforum.com/forum/mercedes-e-class-9/2002-e320-car-will-not-shift-gears-41550/)
LeoKei Mar 5, 2010 04:42 PM
I just purchased a 2002 E320 with 94,000 miles. While driving it today the car would not shift into gears from 1s/2nd.. I ended up driving the car at 4000 -6000 RPMS to reach higher speeds but pretty much had to stay under 30 miles an hour to drive it because it would not shift into a higher gear at all.
There are no check engine lights, no blinking transmission/over drive lights coming up. When in park or idol the engine runs smoothly and without any jerks or RPM changes.
I just left it at a Mechanic shop but he is not a Mercedes expert but he is not a Mercedes expert and may not have all the tools to check it our properly.
LeoKei Mar 6, 2010 08:25 PM
Hello, any mechanics on this site that could help with the issue above?
MB-TECH-38 Mar 7, 2010 02:38 PM
sounds like the shift / conductor plate on top of the valve body . should have codes in ETC module need factory type scanner to check
Jerry
