1995 E320 M104
1995 E320 M104
My 1995 E320 starts fine when the engine is cold, but when it is hot it fails to start. The engine turns over and I can hear the fuel pump working. If I depress the gas pedal about 2" and turn the engine over it starts ok, when I let off the gas it hesitates and run rough (low rpm) and then smoothes out.
I tested the built in led (OBD1) and got a fault code 25 "knock sensor" only. Could this cause the problem or should I look elsewhere?
zwarst
06-22-2011 10:05 PM
sanchezc
04-28-2010 11:23 PM
waybomb
03-23-2006 12:14 AM
