-   -   1989 mercedes 300te questions (https://mercedesforum.com/forum/mercedes-e-class-9/1989-mercedes-300te-questions-48782/)
MinnesotaMercedes Jul 8, 2011 11:10 PM
Hey,
First all am i in the right place?
Alright my questions 1. Is how do i remove the rear door panel? And 2. I have 1 engine problem after a short drive if i go to start the engine sometimes it will crank over but act like its not getting gas...what do you guys suspect?
alex likes benz Jul 9, 2011 03:03 PM
I forget exactly how the panels come off those, but I know that the trim around the handle comes off and there is a 10mm bolt in there, the is a phillips screw around the striker, the door lock knob screws out, and you pull the panel UP and out, just out will break all the clips. I can look at my wagon next week (its locked in the shop for the weekend) and get you a better answer.
The starting problem sounds more like a flood than a choke out. try holding the pedal to the floor while cranking. Also take a listen to the injectors with a stethescope (or a long screwdriver). They should make a high pitched screaming/singing/whistling noise with a faint, fast ticking. If they make a graveling noise or a slow tick they are leaky and need to be replaced. I usually would recommend replacing all 6 at once, but it is kind of expensive to do that.
Alex
alex likes benz Jul 9, 2011 03:10 PM
Also, where are you in MN? I'm in the twin cities and do a bit of cash work at home.
Alex
