1988 300E Engine Tempsensor??
Old Sep 15, 2008 | 04:09 PM
sajohn's Avatar
Default 1988 300E Engine Tempsensor??
I believe my temp sensor is bad this is a pic of the repacement I have been finding online. However the one I have has a darker green top and only two conectionports. Am I looking at the right sensor or am I cross referencing wrong?The one I located on the engine is on the back of the engine on top of the manifold. Please advise.[/align][/align]Thanks, Scott[/align][/align]
Old Sep 15, 2008 | 10:11 PM
cliff's Avatar
Default RE: 1988 300E Engine Tempsensor??
I just replaced that on my 1990 300e and it was black and 4 pronged so I don't know, although there are two, one green and one black...easiest way to find out is to look...my 4 pronger was $36...good luck...cliff
Old Sep 15, 2008 | 10:14 PM
cliff's Avatar
and by the way, that's it...the coolant temp sensor, you have the correct part there.....good luck...cliff
Old Sep 15, 2008 | 10:17 PM
cliff's Avatar
although it's not actually in the manifold, while adjacent it's actually in the cylinder head itself, at least on mine...be sure to use the teflon plumbers tape on the threads as well...cliff
Old Sep 16, 2008 | 05:56 AM
sajohn's Avatar
Thanks Cliff, I'll Give it a try. I just don't know what to do with thethird port, I cannot tell if it shows a normally closed connection or a common.
Hanno
May 30, 2008 10:16 AM
CorvairTurbo
Jan 9, 2006 12:21 PM
92600SEL
Jan 4, 2006 09:55 PM
w_white
Mar 27, 2005 02:34 AM
AR3S
Nov 24, 2003 10:15 PM
