Tip Tronic Transmissions
Old Sep 23, 2008 | 08:03 PM
skigyz's Avatar
Default Tip Tronic Transmissions
I have an '04 CLK500 as well as an '04 E320 4-Matic that seem to "act up" every now and again in the shifting behavior. Sometimes the tranny seems to hang on to the gear I'm in(especially going uphill) but will shift properly when I tap the tip tronic lever and at other times it seems sluggish in shifting from drive to reverse when parking. Since there is no dip stick I cannot accurately determine the fluid level which I feel is the culprit since it has been changed in both cars(using MB fluid) but do not have a local dealer for almost 100 miles to thermally measure the fluid level! Am I on the right track?
Old Sep 24, 2008 | 09:14 PM
Mark Cummins's Avatar
Default RE: Tip Tronic Transmissions
Have a Dealer Inspect the 209 as that year had a defective radiator that leaked coolant into the Auto trans..as the trans cooler is part of the radiator...when it leaks it WILL Damage the Trans!!
Old Sep 26, 2008 | 08:33 PM
skigyz's Avatar
Thanks for the heads up on the coolant leakage into the tranny fluid but it did turn out to be a low fluid level in the transmission and adding a little more at the dealer resolved the issue when it was measured by the thermal device and they did it for NO CHARGE! So nice of them that I brought my '04 E-320 wagon down to have that checked too! Now about my SRS light on the '04 CLK. Turns out that that has to be reset by the dealer because the code is locked out on the scanner.
shoulddt
Jul 20, 2015 02:28 PM
R717
Mar 17, 2015 03:51 AM
BOSTON JOE
Aug 31, 2008 07:57 PM
lgmdaniel
Mercedes A Class
Jan 21, 2008 09:45 AM
spj
Dec 5, 2006 04:41 PM
