-   Mercedes CLK Class (https://mercedesforum.com/forum/mercedes-clk-class-12/)
-   -   tilt wheel (https://mercedesforum.com/forum/mercedes-clk-class-12/tilt-wheel-24428/)
lockmanmd Oct 29, 2007 12:57 PM
tilt wheel
Steering column stopped moving up and down. Still moves in and out. I can hear motor running. Anybody have any ideas if there is anything I can do or reset? Thanks
gmakona Jul 5, 2009 09:40 PM
Hi lockmanmd,
I have 2005 C240.
And I also have the same problem with the steering wheel(up and down).
Did you fix alright?
If so, please let me know what and how.
chassis221 Jul 6, 2009 07:48 PM
usually you can go all the way up and all the way down and hold it at each place then try to go in and out. again, try the procedure a few times and you might have some luck. the colummn looses its normalization and needs to be relearned. but you also could have a bad switch or motor.
chassis221 Jul 6, 2009 07:52 PM
your 2005 c240 is different than his clk its a different set up. you most likley have a broken rubber piece that is used to move the wheel up and down. you can try the same procedure as i told him and it might work. but your c240 has commom issues with the rubber "rods" breaking
gmakona Jul 7, 2009 02:17 AM
Hi CHASSIS221,
Thank you very much for responding to my problem.....It gives me an idea what could be wrong.
I'm still a new comer and learn from Mecedesforum a lots!
I really appreciate that you let me know very nicely.
gmakona Jul 7, 2009 11:30 AM
Hi Chassis221,
Sorry to bother you again.....
I'm going to bring to the dealer or the Benz Specialist to fix.
Is it a big job to replace if the rubber "rod" is broken?
I appreciate if you owuld give me some idea?
Thanks!
chassis221 Jul 7, 2009 08:13 PM
cheap part, but maybe 2 hours labor depending on who works on it.
gmakona Jul 8, 2009 02:45 AM
Hi again,
Thank you ver much for your geat help!
I better check around where I should bring!
Living in Hawaii, everything seems like more higher.....the labor fee at Mercedes Benz Dealer in Hawaii is $125 per hour now.
Today the Dealer gave the estimate is $1,000(part & 4 hours lobors).
Again thank you very much and I really appreciate your help!
