HELP a/c Blower Staying on
have 2001 clk 430.. i had same problem,, dealer found that outside drain was clogged and caused water to run in a way that caused some kind of short, thankfully under warrenty....not sure if you have same drainage prob but sounds like you have some kind of a/c short....to help keep my battery from going dead which yours eventually will, i found fuse for a/c and pulled it so that it would shut off...good luck
al_in_nyc
Jun 19, 2008 12:29 PM
fay3131
Jun 17, 2006 02:01 AM
