Fog light bulb replacement
Jack up the car, remove the plastic splash guard(2 screws), snap off the wire that holds the back of the fog light, use flashlight to look into the back of the foglight, you should see 2 wire clips that meet in the center, unhook each one, the bulb can then be removed, attach new one and replace everything in reverse order. Both sides are the same.
iorillosa
Nov 20, 2007 12:18 AM
