CLK won't move
Old Jan 17, 2011 | 04:24 PM
mattclk's Avatar
Unhappy CLK won't move
Hi, bit of a problem with my 55 plate CLK 320 CDi. Basically it won't move! The ABS warning light has come on out of nowhere and I can't engage any gear (auto). Was fine at lunchtime but come teatime it's decided it doesn't want to move an inch. Have tried disconnecting battery to no avail, any ideas how I could at least get it moving to put it away?
Old Jan 24, 2011 | 07:05 PM
samvel1981's Avatar
remove a ABS fuse it should trick your traction control
the fuse is under hood big orange color 40AMP
Old Feb 9, 2011 | 10:18 PM
sha512's Avatar
my clk thinks I have handbrake on once in a while after sitting on the parking lot for ~8 hours. I have to pull handbrake off and then it goes back to normal.
Old Feb 9, 2011 | 11:12 PM
chassis221's Avatar
could just be a sticky e brake switch or the cable needs adjustment.
Old Feb 18, 2011 | 11:59 AM
zeff's Avatar
on my w208 chassis it did this, it was the brake peddle switch, it does alot more than work the brake lights. There only cheap and take five mins to swap and its a common fault.
I wounder if your car is the same as mine in that at the bottom of the gear stick shift pattern theres a little flap that you can push a pen into and it releases the gear shifter lock so you can put it in N and start the car.
stang0303
Dec 21, 2021 08:49 AM
Godfather Benz
Dec 25, 2012 10:44 AM
Goldenvoice
Nov 21, 2009 08:52 PM
rksharp
Sep 23, 2007 01:59 AM
gotta6.9
Nov 8, 2006 03:08 AM
