clk camber adjustment
hi,im wondering can my 2001 clk200 coupes camber be adjusted as i have put lowering spring in and its eating the inside of the tyres?car is driving dead straight and not pulling left nor right.
RE: clk camber adjustment
when you put lowering kit in did you take it to the front end shop? if not you should, lowering it changes everythinghttps://mercedesforum.com/micons/m8.gif
i have had the car in for 4 wheel alignment and the guys there said the camber is off a mile and the suspension cannot be adjusted to sort this.I am told that mercedes main dealer will have to change original bolts in suspension to adjustable bolts so that camber can be rectified.I have contacted local main dealer and booked her in to get sorted.p.s for all u guys out there its not so simple just throwing on a set of 19's and a set of springs
We have K-MAC camber kits available to correct negative camber issues.
| All times are GMT -5. The time now is 03:09 AM. |
